v6 to v8 carbed. wire ?
Old Jan 9, 2006 | 12:09 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
no computer. need wire color for 87 2.8 switched 12vdc for hei dizzy.
out of main harness.
2-reds = 12v feed to fuse panel
1-purple = to starter
1-pink with blk stripe. this wire is switched from ignition switch but reads about 120 ohms to red wires. can i use this for my hei or is it for something else?
Old Jan 9, 2006 | 05:20 PM
elky74's Avatar
Car: 82 Firebird, 71 LeMans
Engine: GMPP 350, 400 PMD
Transmission: TH-350
That sounds like it'll work, but not 100% sure.
Just checked Chiltons and there's a pink wire coming from the ignition switch. You should be able to access this wire under the dash. This is the same one I tapped into for two of my cars I converted to hei from points type distributor. It should work as long as it's only hot with the key on. I also read on another thread to put a 15 amp inline fuse on this wire. Sounds like a good idea.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
