305tbi to 350 card..just a few ?'s
Old Jan 28, 2006 | 04:19 PM
hilliusracing31's Avatar
Car: 95 Chevy 1/2ton, 91 Geo metro, 89 Camaro
Engine: truck and race car have 350's, geo has a 1.0L
Transmission: truck is 5spd, race car is auto, geo is 5 spd
Ok, I have a 1989 camaro RS. The 305 tbi is getting pretty weak and I just got done building a 420hp 350. I want to put it in the camaro. I want to get rid of the tbi and egr systems. The 350 has a carb on it. Some one was telling me that the speedometer is controlled by the computer system and will not work when I do the conversion. I was just wondering what you guys do. Is there a harness I have to buy cause I want to get ride of the computer and all.
thanks,
Justin
Old Jan 28, 2006 | 04:48 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
My 89 Camaro (Formerly LO3 TBI) has a gear driven speedometer not at all controlled by the combuter. Here is what it looks like after the switch to carb:
Lance
Old Jan 31, 2006 | 06:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
hilliusracing31, welcome aboard.
The VSS is separate from the ECM. Those cars with a transmission-mounted VSS have a module that is not dependant upon an operational ECM.
Old Feb 1, 2006 | 11:14 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
I just did the swap and I have no speedo probs.
Old Feb 2, 2006 | 10:21 PM
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
i did a swap on mine, never even thought about it, but yea it works fine, other than its off a little because of the 3:73's
Old Feb 3, 2006 | 11:33 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
Camaros are gear driven(cable) til 1990
Old Feb 4, 2006 | 05:16 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
speedometer
i have a 88 iroc and i guess you answered my questions with the speedo but i have 29 inches in the back plus i will be putting in 342s in the rear so i have no choice but to get a programable speedo right?autometer is the only one i could find since i need a three and five eighths hole.
Old May 8, 2007 | 11:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: speedometer
No, you can change the speedometer gearing in the transmission.
Old May 9, 2007 | 01:45 PM
Toxinz's Avatar
Car: 92 camaro
Engine: 355
Re: 305tbi to 350 card..just a few ?'s
Your going to have to find out if your car has A speed buffer box that is seprate or if its built into the ecm. If it built into the ecm you going to have to get a speed buffer.
http://www.hioutput.com/tech/speedo.html
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
