which motor mounts
Old Feb 3, 2006 | 09:24 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
which motor mounts
i am putting in a new engine with hedman lt should i use the oem mounts ?what are the mounts to buy so my headers will line up the best
Old Feb 4, 2006 | 01:29 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Use OE mounts. While the motor is out, you might as well put new ones in. I recommend that you take apart your factory ones and put in poly bushings. Dont use solid mounts (speaking from experience).
Old Feb 4, 2006 | 04:56 AM
dwint's Avatar
Car: 88iroc
Axle/Gears: 373
motor mounts
i thought the poly mounts were alittle taller and made it harder for the headers to match up?i will be useing the hedman xtentions
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
