motor mounts
Old Feb 14, 2006 | 06:30 AM
joshnryandad1's Avatar
Car: 1991 camaro rs
Engine: 3.1
motor mounts
hey fellers another question: i'm putting a 350 in the place of my 3.1 and would like to know what motor mounts i need? do i need both upper and bottom from a v8 camaro?
Old Feb 14, 2006 | 06:32 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yes, you will need both the mount on the frame and the clamshell that goes on the motor itself.
Old Feb 14, 2006 | 10:13 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
iirc, the front lower tabs on the v8 frame mounts will hang over the k-mbr, and yes, the break line can be moved rearward enough to clear the mounts. I did this in my ride w/o a problem (other than figuring out th eholes in th emounts & the holes in frame hint: rotate the mounts if they don't align )
Old Feb 14, 2006 | 05:52 PM
Car: 1991 camaro rs
Engine: 3.1
guys i appreciate the help! will motor mounts froma t/a work? the local salvage has a wrecked 89 t/a that i've been taking parts from! i know i need new bushings .
Old Feb 14, 2006 | 05:58 PM
Engine: 5.7 / 7.4
yes, you'll have to grind off the rivet heads to swap in new bushings. I used my $20 oddlots bench grider, worked just fine
Old Feb 14, 2006 | 06:05 PM
Car: 1991 camaro rs
Engine: 3.1
that would be worth the extra work i think! thanks
Old Feb 14, 2006 | 06:28 PM
Engine: 5.7 / 7.4
oops, must've been all the dust I'm inhailing... I had to grind off the rivets for the torque arm bushing, I jsut got the $10 new bushings from AZ. $20 new w/warranty is probably a better deal than the yard ones
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
