Engine Swap (Different)
Old Feb 19, 2006 | 07:41 PM
slygy0's Avatar
Car: 2004 hemi ram, 1970 442, 1989 350 iroc 1le
Why am I seeing a lot of Oldsmobile 350 v8's out of 1968-1972 cars in third gen cars? are the mounts the same? I own 2 1970 442's with olds 455 engines. i know the tranny patterns are different and so are the driveshaft. what i am wondering now is will a tpi engine go the other way and swap into a 1968-1972 a body?
If there is something I am missing I sure would love to be more informed. A fuelie tpi 383 and a t56 in my new 1970 442 g machine project would sound interesting.
Thanks for any info in advance.
Old Feb 19, 2006 | 09:57 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Use the SBC motor mounts.
Old Feb 20, 2006 | 04:24 AM
slygy0's Avatar
i know to use the SBC motor mounts but i have been told that the 2 engines should not clear the opposite 2 car's firewalls.
Its just odd that I am seeing so many olds motors in camaros, and i was wondering if anyone actually did the swap and what were the other issues.
thanks
Old Feb 20, 2006 | 05:11 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
The '70 Olds 442/cutlass has all of the same motor mount holes on the k frame that a '70 Chevy chevelle/mallibu has.Or the '70 Pontiac GTO/Lemans and Buick GSX/Skylark for that matter.A SBC will bolt into a '70 442 just as easy as it bolts into a '70 chevelle.Just have the right motor mounts in the right spot for which ever swap you are doing.I know that on some older cars like the '70 Nova a larger HEI distributor will hit the firewall.Nothing that a few light taps with a hammer won't fix
Old Feb 20, 2006 | 08:06 PM
slygy0's Avatar
so in theory i should be able to bold a lt1 or ls1 or tpi engine to my 1970 442. now i just need to find one with a six speed attached. anyone know of one?
Old Feb 20, 2006 | 08:07 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The guys at Tennessee Auto are putting an LS1 in a 442 right now, and it's becoming a nightmare with getting things to work right, and they're putting an auto in.
Old Feb 20, 2006 | 08:24 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I guess I should have said a 1st generation SBC. the TPI motor will bolt right in,but I don't think the LT1 or LS1 are direct bolt ins.A TPI 383 with a 6 speed shouldn't be to complicated.It would be best to have a donor car to scavange all the TPI related things you will need.Looking at the LT1,LS1,TPI thread should help you out.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
