engine brackets
Old Mar 19, 2006 | 04:11 PM
gasman305h.o.'s Avatar
Car: 1984 Pontiac Trans Am
Axle/Gears: 9 bolt posi 3.27
engine brackets
i"ve had my car torn apart for about a year now, and i took pictures of where all the brackets go, but thanks to the help of another they are gone. so i was wondering if anyone had a pictures of a non serpatine fbody with a/c?
Old Mar 19, 2006 | 08:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are a bunch of photos here:
https://www.thirdgen.org/techbb2/sho...d.php?t=279581
Old Mar 19, 2006 | 08:19 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
I had the same problem when I put my car back together, I found this pic on this website, it helped a bunch. The spot on top of the driver side of the motor where something is missing is where the compressor goes, its just not on there in that pic. the power steering pump goes on the bracket below that. the alt is on top of the pass side and the air pump if equipped is below that. shows the bracket arrangment really good though
Old Mar 19, 2006 | 08:51 PM
thanks alot, thats exactly what i needed, now i just hope this beast runs again!
ZMWojnar
Brakes
May 12, 2019 10:43 PM
toronto formula
Nov 10, 2015 06:17 AM
sreZ28
Aug 14, 2015 07:48 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
