Old Mar 19, 2006 | 05:31 PM
livewire195's Avatar
Well I have a 92 firebird, and unfortanetly its a 6cyl, Im not to great with cars anyway, but I'd like to drop a 8cyl in it, and convert it from automatic to stick. OR
I was also thinking, turbo the car, and then swap out the trans because mines going.
what do you think?
Old Apr 9, 2006 | 01:09 AM
88IROCZZ4's Avatar
Car: 1985 Z28 Coupe
Engine: Carb'd LB9 .030 over
Transmission: TH700R4
Axle/Gears: Posi 3.42 10-bolt
if your tranny is going and you want a V8, you will be better off swapping in the V8 and a new tranny at the same time. the bellhousing on the V6 transmissions will not bolt to an 8cyl.
then, once you have the engine and tranny worked out ....
...drop in some twin turbo's
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
