received engine pull out, need help
Hello,
I purchased a 2002 engine pullout for converting my 91 Z28 to an LS1 w/ T-56. However, I received something that I am not sure what I got. I know I can search, but at this point I need some reassurances as I just supposedly plonked down $5678 for a 33K miles pullout.
Block # 12559378.
Heads # 241.
Exhaust manifolds have EGR.
Intake #12561184.
Gas tank is plastic, any particular numbers I should search for?
Fuel lines are metal.
Is a 2002 supposed to have AIR injection, and if so, where do I identify it?
I did not receive an ECU, so I can't identify that, though I was supposed to get it.
Are there any numbers I need to search for?
I'm at a loss and a bit flustered as the company I bought it from is supposed to be reputable. Before calling them or sending off an e-mail, I need more information as to identify what exactly do I have and to basically calm down. Is it really an 02, or not.
Thank you very much for your assistance.
Block # 12559378.
Heads # 241.
Intake #12561184.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
As long as the heads are not perimeter bolt, it isn't a 98 model, 99+ used the 241 heads if I remember correctly. PCM's are the same from 98 and up, so that doesn't really matter much, gas tanks are the same, if it's a 2002 motor it should have an LS6 intake on it, might want to try and find a part number for the LS6 intake, as for the rest, I don't really remember.
When I was deciding what to put in my 88 it seems that learned the 01-02 did not have egr. There is a recent thread here with some of the information you need, I did not tag it so I can not recall just when it was posted. Did you get the engine from ebay? I finally found a decent lt1 locally and decided to go in that direction.
