350 from a truck or van?
Old Mar 24, 2006 | 02:43 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Are the 87 & up truck 350's roller cam blocks and 1 piece crank seal or no? Will the heads bolt to a 91 TPI base? i need a 350 longblock for my new Formula project and I'm checking the local yards to see whats out there. Are the 350tbi heads different from L98 heads? Thanks for the help.
Old Mar 24, 2006 | 03:10 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
yes
Old Mar 25, 2006 | 03:30 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yes, they will bolt up to a 91 TPI base.
Yes, TBI heads are different than TPI heads.
Old Mar 25, 2006 | 01:51 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a 1991 block out of the 91 suburban we junked. they are roller blocks and one piece rear main seals. The heads are swirl ports and don't flow like L98 heads, but they are easy to find one out of the boneyards. Also sometimes pulling out the stock lifters out of the block is difficult since the roller blocks have non-roller lifters installed which can mushroom the lifter bored a bit and make lifter removal a real pain. I so far have only removed 4 lifters out of 16 out of that block with 112k on it and oil changed every 2500 miles. I have the lifter puller tool, I'm about ready to use a slide hammer on them.
Old Mar 25, 2006 | 06:45 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
If and when I have that problem i pull the lifters up until they stick, then pull the cam out and gently knock the lifters down into the cam bore. its easier and does less potential scoring to the lifter bores. I would only do this though if your going to replace the cam bearings because you run the risk of hitting and knicking one. once they are in the cam bore you can pull them out with a magnet. they go down fine, just not up from the varnish on the bottom of the lifters
Old Mar 25, 2006 | 06:56 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Thanks for the info guys. I found a complete TPI 350 from a 87 bird at a boneyard and its for a real good price so I will probably go for that and then sell off the spare TPI Intake for some cash
junkcltr
Aug 2, 2019 11:12 PM
DJanes97
Sep 1, 2015 02:55 PM
89gtaforsale
Aug 24, 2015 09:32 PM
Eric-86sc
Aug 24, 2015 09:01 PM
