2.8 v6 to a 383
Old Mar 21, 2006 | 10:29 AM
HorsePoison85's Avatar
2.8 v6 to a 383
hey first of all Hi im new i have a 1985 chevy camaro 2.8 v6 fuel injected.
do u guys have any advice on where i can get some parts from new or used?
I plan on doing an 383 swap this summer i already have complete motor minus intake and carb. i also have a turbo 350 trans i need a set of heads and a good cam also a new crossmember i think and driveshaft any help ill appretiate it
thanx
matt
Old Mar 21, 2006 | 03:39 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
driveshaft, i had one made at a driveshaft shop stock diameter but a couple sizes thicker wall and it twisted up. so then i went to fleetpride and had one made that will never break even if i go to a nos big block. spohn for frame conectors, the rest from summit. summit has great service and fast shipping. ive bought thousands of dollars worth from them for the bird and my jeep, truck, etc.
ps if your on a budget id hold off and get everything converted and running well before you spend money on heads and cam. the extras get very costly.
Old Mar 21, 2006 | 07:36 PM
yes i am on a lil budget but only becouse im 16 and im not in any hurry to get this gone as long as its done by the end of summer its fine i have plenty of time as well as i make good money so i think ill be alright
Old Mar 22, 2006 | 09:43 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
still, you'll want to have the trans done, TQ, drive shaft, gears, lim slip, axles, frame conectors, trans conversion kit, airbags,rear shocks. i would consider these minimums for a 383. if you are going to get slicks you need a driveshaft loop. spohn has a kit to convert the crosmember for a 350 while giving you a mount for the tourque arm and a loop. i wish i went that way initially. thats not counting anything in the engine bay. you'll need a fuel presure regulator, radiator, and various hoses, lines, and cables
Old Mar 23, 2006 | 08:54 AM
Epro's Avatar
Car: 95 Camaro Z28
Transmission: 4L60E w/ shift kit
Axle/Gears: 3.23s
You're 16, you'll be heartbroken if you drive that car you spent all that money and time on making fast, in a ditch.
Just drive your V6. I'm 17, still saving for my thirdgen ($3300 saved) and the main reason I'm not getting a GTA is so I don't get devastated when I drive it into a ditch. Keep in mind, I have above average driving skills for my age.
Not to mention, there is a guide for going from V6 to V8 above. It's not cheap, much cheaper to start with a V8 car.
My two cents
You might want to read this:
https://www.thirdgen.org/forums/engine-swap/229665-v6-v8-swap-read.html
Old Mar 23, 2006 | 10:10 AM
ljnowell's Avatar
My two cents
https://www.thirdgen.org/forums/showthread.php?t=229665
I wouldnt say that its cheaper to go with a v8 car to start with, just less work. If you are stepping up to a 383 combo or something like that, you would want to replace just about everything you would when doing the v6 > v8.
Old Mar 23, 2006 | 11:09 AM
yes that true but its a race car not by anymeans a street car im going today to pick up the block
Old Mar 23, 2006 | 11:56 AM
ljnowell's Avatar
Youve lose me here. If its a race car, it really doesnt matter. Everything that makes a difference between the two will be replaced. Get whichever you can get the cheapest deal on, and run with it.
Expect to change everything. Mounts, trans, radiator, exhaust, etc.
Old Mar 26, 2006 | 02:24 AM
Ebby's Avatar
Car: Red 05 Viper SRT 10 & Yellow 03 Z06
Engine: 87 Camaro - 355 TPI Custom
Transmission: 5 Speed BW World Class
Axle/Gears: 3.73:1
The guy I know is Tom at House of Camaro: http://www.houseofcamaro.com/
This guy's entire life is taking apart camaros, trans ams and firebirds and selling off the parts for very reasonable prices. He's exceptionally knowledgeable, very well organized and really friendly too. I swapped my 2.8 V-6 for with a 355 TPI and a lot of the small B.S. parts that I needed I got from him (fuel injector retainer clips, special bolts, screws, pullies, brackets, etc.). He's got it all.
Good luck. Oh, and buy yourself a lot of hard liquor - you're gonna need it for this project.
86'Frankenstein
May 22, 2007 05:48 PM
86t/a owner
May 21, 2006 10:35 PM
brad_26
Jan 6, 2006 11:37 PM
kretos
Nov 26, 2004 12:18 AM
pskel350
Dec 16, 2002 12:35 PM
