making a 2.8 into a stroker ?
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
how would i go about making a 2.8 a stroker (like a 383)
i'm basicaly looking into seeing the best power i can get outta a 2.8 as my 3.4 fell through
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
3.1 or 3.4 crank.
Then 3.1 pistons (bored to whatever you bore too).
Thats why everyone just says, get a 3.4. Its already bored and stroked.
Car: 89 Iroc
Engine: lb9
oh i know, i wish i could get my hands on another 3.4, problem are they are about as rare as a mint tta up here.p
and mine fell through
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
we have a crap load of them down here, what ya want i bet you could get it shipped to wherever you are pretty easy
that depends i could pull one for you for a fee, the engine would cost 100 bucks plus whatever you wanna pay me fora day in the cold at the yard lol, or you can get one already pulled for anywhere from 450 to 600, they had a few when i got mine
Does any one know the lonegest stroke the 2.8 - 3.4L can use. A custom crank might be a worthy mod. If I remember correctly the 3.1 and 3.4 had the same stroke but a larger bore.
You can get more TRQ by useing a longer stroke vs. going with a larger bore. You should be able to make more power from a 3.4 built with a longer stroke and the bore of a 2.8 or 3.1.
Maybe a 3.4 crank with shorter rods would be chearper way to go. maybe even get more than a 3.4, but I am not sure how to calculate displacment.
mhatfield 14
Oct 24, 2015 07:48 AM
Mickeyruder
Sep 2, 2015 02:45 PM
