LT1 with Vortech Supercharger?
Old Apr 25, 2006 | 11:34 PM
AdamsIroc-Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: Built 355 LT1 T-Trim
Transmission: T56 6 spd
Axle/Gears: 9 bolt 3.73 gears
Hello everyone, I'm new here. I have an 87 IROC with a 95 LT1 engine (built motor). I purchased a Vortech S trim kit for it as the motor has been built for boost. My problem is the kit does not fit in the 3rd gen and the blower goes right where the steering box is. I tried a set of 3rd gen mounting brackets but they also will not work as they do not fit the LT1. I am currently installing a tubular k-member and looking to covert to rack and pinion steering to rid myself of the steering box, in hope of having room for the blower. I was wondering if anyone on this site has done a supercharged LT1 in a 3rd gen and how it was done.
Some pics
Old Apr 26, 2006 | 06:01 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
customized brackets
Old Apr 28, 2006 | 10:42 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't know if it will work but you might look into Corvette front accessories and brackets. I had a '94 Vette with a S-trim supercharged LT-1 and the supercharger was on the passenger side of the engine. Another option is to look in to converting to manual steering from an S-10 truck. I don't know if it will give you enough clearance but it's an idea.
Just a helpful hint... I found the stock hat on the supercharger (metal air intake cover) to be restrictive. I replaced the entire intake with uniform diameter plastic tubing and got an extra 3 psi at the manifold for a total of 12 psi of boost. The result was an extra 75Hp at the wheels for a total of 420 RWHP on pump gas with stock injectors and computer. Much more potential if I had just tuned the fuel and timing. But regardless the car ran a best of 12.2 @ 122 mph on street tires. Never used slicks or drag radials. I got the tubing from Anderson motor sports in Illinois (Ford dealer specializing in high performance Mustangs). It doesn't matter what you get. Just buy some elbows and straight sections and cut them to fit using a hack saw. You can join the pieces together with silicone tubing and heavy duty band clamps. Just give Anderson Motor Sports a call and they will get you set up.
Good luck!
Old May 5, 2006 | 01:30 AM
iroc22's Avatar
Originally Posted by 1981LT1
customized brackets
That might be the only route in this case
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
anesthes
Sep 30, 2015 07:48 AM
L0tuS
Sep 4, 2015 11:16 PM
