Grounds and starter.....
Old Apr 26, 2006 | 06:42 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Ok I just completed a swap and I need alittle help. Can I ground the same wires that were in the back of my iron heads to the back of my alluminum(sp) heads? Also, I have a ministarter and I need a picture or a good desription of wireing it up. I think I have it right but my car has nothing. No dome light nothing. I can turn the motor with the ol screwdriver on the starter way but when I try to the key...nada. I have the battery wire hooked up to the s side of the starter and the other four on the other side. Is there another wire that hooks up with the battery wire on the starter? Help if ya can.
Old Apr 26, 2006 | 07:47 PM
eXesiv|83ta's Avatar
Car: 1983 Pontiac Trans AM
Engine: 355 chevy
Transmission: 700R4 Built
Axle/Gears: Built 10 bolt 3.73 gears
are there three terminals on the starter?
Old Apr 26, 2006 | 08:17 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The ground wire shouldn't see a difference between Iron and Aluminum, metal is metal. If it did see a difference then spark plugs wouldn't fire correctly on aluminum heads.
My mini (generic kind like the one Jegs and Summit sells) has a spade, and connector posts. I have a purple wire on the spade and the rest of the connectors on the single post.
Be sure you ran your battery to chassis and battery to motor grounds again.
Old Apr 26, 2006 | 08:59 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Yes there is three posts, well two big and the small one. I hooked everything to the same post and it all works but thats just because they are ALL TOGETHER I know, Is this right?? The only thing to the second post is the small black wire that goes to the starter. What do ya think?
Yeah I see what your saying about the ground. I hooked them up the same way and they are working. Two to the back of the head and my battery is between the smog bracket and block.
Old Apr 26, 2006 | 09:04 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Sorry I also have the summit ministarter. I think it was a powermaster or something. It says Hitachi on it I know that....
Old Apr 26, 2006 | 09:16 PM
Engine: 383 SBC
I'm pretty sure that's correct... I'm fairly sure the purpose of the lower stud post is just to provide power connection for the drive.
If it's that big of worry to you call up jegs...
1-800-345-4545
Press the buttom for Tech Line. Tell them you bought the Heavy Duty Hitachi Starter #555-10022. But you questions over the wiring and make them explain it. (JEGs Tech Line use to be toll-free, while Summit redirects you to a non 800# line)
And of course report back, so I can confirm I'm not losing my mind here.
Old Apr 26, 2006 | 09:18 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Kewl, thanks for the help.
$750 L98
Feb 1, 2025 02:25 PM
Falcon50
Aug 22, 2020 03:26 PM
Thaney9
Oct 15, 2015 06:37 AM
lewandom
Oct 1, 2015 08:15 AM
