Stock v6 to Buick v6?
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Does anyone know of someone in the Los Angeles area making/dealing/selling kits to swap my stock 3.1 to a Buick turbo v6? I have a 91 bird, should I even be thinking about this?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
bellhousing bolt pattern difference
find a buick olds pontiac caddy tranny
find a donor vehicle with a buikc v6 in it and take the engine mounts and block mounted brackets and p/s pump setup and such
use all that in the bird, and a few other things from the donor car, exhaust, etc
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
https://www.thirdgen.org/forums/engi...Buick+Turbo+V6
Hey
Thanks for the advice guys. I'm new to the Thirdgen family; I used to be a Ford guy, then I woke up one day and decided to get something RELIABLE. The reason I'm thinking Turbo Buick is because I can't seem to find much in the way of performance parts for my engine (intake, headers, etc...). Anyone know of a good place? If not, I think the Buick might be my best best. Thanks again.
