installing 96 lt1 in 99 s10 extreme
Old May 2, 2006 | 10:30 PM
99lt1s10extreme's Avatar
Doing a complete body off frame conversion on a s10 extreme got the engine and 4l60e trans from a 96 buick roadmaster came complete as engine trans and engine wiring harness with ecm.I have all the frame done and completed with the engine and trans fit in place.What i am looking for is wiring diagrams for the 96 engine and trans.Have done a cpl of the older tpi swaps into the early body s10s with not much wiring problems at all with a little reading and studying diagrams.I'm reading and hearing that i will have to use two ecms one to run the trucks abs cruise and a few other things and the 96 ecm for the engine,trans,and ac.Building the truck to look as stock as it was and as close to what it woulda been if gm had built it that way.Using catalytic converter,02 sensors,air pump abs brakes.if anyone has any helpfull hints about how to go about finding this type of info i sure would be gratefull.
Attached Thumbnails installing 96 lt1 in 99 s10 extreme-dcp01647.jpg   installing 96 lt1 in 99 s10 extreme-dcp01652.jpg   installing 96 lt1 in 99 s10 extreme-dcp01650.jpg
Old May 2, 2006 | 11:00 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
I hope you get the help you need before this gets locked.Please don't take offense when it does,our mods are super guys,but they do have to follow the rules.
PS:Looks like a killer project!!
Old May 3, 2006 | 02:10 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
You would find better help on some of the LS1 and LT1 boards.
Sweet project good luck with it.
Old May 7, 2006 | 04:50 AM
JB97C5's Avatar
Car: Silver 1980 Corvette (L82 w/TPI)
Engine: L82
Transmission: TH350
Originally Posted by 99lt1s10extreme
Doing a complete body off frame conversion on a s10 extreme got the engine and 4l60e trans from a 96 buick roadmaster came complete as engine trans and engine wiring harness with ecm....
I'm going to hijack your thread because even though it is not about an F-body, it is relevant to ALL sawppers...
Make sure you check the block and intake numbers. You may not have a 5.7- the Caprice and Buick are notorius sources for so-called 5.7 motors that turn out to be a 4.3 upon closer inspection.
GREAT SITE FOR F-BODY SWAPPERS-
This site explains the differences in the LT1 5.7 and the L99 4.3...
LT1 History
And...
GM LT engine - Wikipedia, the free encyclopedia
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
