TBI to TPI swap, few questions...
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Ok, I'm in the process of swapping out a L03 to a 350 w/ TPI (S.D.) Can I use the water pump and radiator from the 305 TBI to cool the modified 350 TPI? That radiator just seems small to me....thanks-
the water pump and radiator are identicle assuming that they both were serpentine to begin with. i see no problem.
the TPI radiator is just a tad thicker, but i dont see it making that much difference.
Last edited by michal_larson; May 7, 2006 at 06:09 AM. Reason: Automerged Doublepost
Car: 1989 Camaro RS
yes the car is serpertine setup. I guess I can always change the radiator later if I have probems later on.
Sanjay
Aug 12, 2015 03:41 PM
