Engine Pull Question
Old May 8, 2006 | 09:57 AM
TheWesman's Avatar
This weekend I spent working on pulling the engine out of my 84 computer carb'd Z-28, and have a question. I'm almost ready to lift the engine up and out. I only have to finish removing the motor mount bolts and disconnecting the wire harness at the rear of the heads/block.
Can the wire harness be unbolted at the back of the heads/engine block easier if the engine is first lifted up a couple of inches and moved forward with the engine hoist?
Assuming the wireharness has enough slack in the right direction, I believe this would give me more clearance to get between the engine and firewall to get at those harness bolts. Is this correct?
TheWesman
Old May 8, 2006 | 07:47 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Yes you can lift and move the engine forward to get to the grund bolts on the back of the heads. I did the same thing on my 86Z with vin H.
Yes you can lift and move the engine forward to get to the wire harness and ground bolts on the back of the heads. I did the same thing on my 86Z with vin H.
Old May 9, 2006 | 09:02 AM
TheWesman's Avatar
Cool, thanks for the info. That will save me a bunch on knuckle busting.
TheWesman
Old May 10, 2006 | 02:59 PM
ckeene502's Avatar
crap...i just took a engine out of a parts car and just cut the wires(wanted not to that). i learned a new tip!!!
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
