need to swap knock sensor AND esc?
Old May 12, 2006 | 07:47 PM
Overspendin''s Avatar
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
After a search I've found more opinion than fact...
I've swapped my 1988 305 auto tpi setup for a new zz4, 5 speed tpi and a new chip from Fastchips.
I have replaced the knock sensor but do I also have to replace the ECM and if so, specifically which one do I need?
Thanks if you can help.
Old May 15, 2006 | 01:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need a 350 knock sensor on the block and the module mounted on the firewall.
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
gwade12
Aug 8, 2015 08:17 AM
