191 V6 to 400SB V8
Car: 1992 Firebird
Engine: 191cu.in 3.1L
Transmission: automatic 700R4
191 V6 to 400SB V8
Guys i got a wee-tad of a problem. I just got a chevy 400 carborated small-block that is in great condition. My bird has a little V6 TBI that is running good but in about i would say a year it will be time to swap. My question is when im ready to swap what all will i have to do. Thanks
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Car: 1992 Firebird
i have read that before and my question is will i need to reinforce anything because the engine is bigger than anything that goes in a bird of our gen's
Engine: 3.0L/183
subframe connectors are a must.
It depends on the build up.
is it an auto or 5 spd ?
how much HP and torque will the engine produce ?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
, subframe connectors are a must. Even if you don't put in a larger engine.
Profile says auto, so let's assume he's got TH700R-4. Regardless, doesn't matter, because neither V6 tranny works with a V8 (you can "force" the T5 to "work", but not the bellhousing).
Car: 1992 Firebird
its an auto. with stock everything the only modifing im gonna do to it is put headers and true dual exhaust on it
Engine: LS1/LQ4
The sticky is intended to cover what needs to be done to take out a factory V6 and put in a V8.
What you do to handle power is a completely different topic.
But, you need to get a different transmission. It needs to be built to handle whatever the 400 puts out when you get done with it. Same with the rear end - the factory unit will handle it if you don't go crazy, but will lunch itself with the torque a 400 can be made to put out when coupled with traction. Same with the chassis/suspension, it will be okay for daily driving and mild strip use (assuming you do SFC's), but you start putting down some numbers you're going to want better than stock.
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
check out my sig got me into the low 11's....tourqe arm is a must. Mine twisted the factory arm. made by spohn.
