Should I have to do this to pull a motor
Old May 18, 2006 | 03:47 PM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
hey,
im just wondering if im the only one with this problem. I cant pull my engine from the front of the car without pulling off the whole front end. is this because of the hoist im using? the ram of the hoist hits the front end of the car before the hook can get anywhere near the center of the engine. has anyone pulled their motor from the side? that was my next guess (i already took the whole front end off my camaro)
thanks
Joe
Old May 18, 2006 | 04:32 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Disconnect the engine from the transmission and torque converter. Pull the engine only. Hook the lift chain to the motor chain as best you can and then lift the motor off the mounts and move it forward in the engine bay. Put the motor down so it rests in the bay in front of the engine mounts. Re-attach the lift hook in the middle of the motor chain and lift the motor all the way out. You can also remove one front wheel and support the A arm with a jack stand and slide the cheery picker in from the side. I didn't need to do this.
Reverse the process to reinstall the motor. Easier to do with the water pump and front accessories removed. You don't need to remove the hood either. just detach the hood lift cylinders and prop the hood open further.
Old May 18, 2006 | 05:35 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
yeah... the birds are a pain...
I had to lift from side, move it forward 6-12 inches, then go back to the front.
I pulled engine and trans.
I have alreadt decided I am gonna make new legs and slide bar for my picker that are about 18 inches longer...
Old May 18, 2006 | 06:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From the side isn't bad if you've got the room. That's what I did.
Old May 18, 2006 | 07:35 PM
thanks all
thank you for ur responses. i measured and figured that it would work from the side, but i wanted to make sure before i got too deep into it. when you pulled the engine from the side, where did you let it rest, is there a certian position or place you can set it where no damage will be done?
Old May 18, 2006 | 10:56 PM
V6sucker's Avatar
Engine: blown up
I slapped a 2X4 on the cross member and let her down slow. Bottom of the oil pan. The rad. was already out as well. I also made sure to drain the tranny before doing this. So either do that, or get a butt plug for it... 1 1/4" I think it is...
Old May 19, 2006 | 07:11 AM
ok, thanks
Old May 24, 2006 | 07:18 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
never had that problem with the six or v-8 swap
Attached Thumbnails Should I have to do this to pull a motor-image002.jpg   Should I have to do this to pull a motor-us-1478.jpg
Old May 24, 2006 | 09:05 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
With the right size cheery picker it is not a problem =)
more pictures
Old May 24, 2006 | 03:39 PM
BlackRabbitZ28's Avatar
Car: 1991 Z28 5-Speed
Engine: 305TPI
Transmission: 5-Speed T-5
I know what you mean about the right size picker. We have an overhead crane at work. Makes it soo nice for pulling engines.
LMAO, those pics crack me up. I'm sorry but pulling the engine out of an 80's model car is your driveway/front yard is soo ghetto.
Old May 25, 2006 | 06:31 AM
Engine: 406
MIne was the driveway infont of the garage ..couldnt get the picker to clear inside the garage....gotta do what ya gotta do! Ghetto is a place in Louisiana!
Steve78LT
Feb 24, 2016 12:15 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
