IS THIS A GOOD MOTOR?????!!!
Old May 31, 2006 | 04:21 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i want to build up a motor to put out between 400-500hp. found a block not far from my house for $75. its a mid 70's 350 2blt main and a 2 pieace rear main seal.just wanted to see ur input on it.
Old May 31, 2006 | 05:03 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
No.
2 bolts are not that strong at all.
That is the reason they went to 4 bolt on alot of the higher HP cars/trucks...
The rear main, they are all 2 piece till 86/87 then they went 1 piece.
Old May 31, 2006 | 06:22 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
There's nothing wrong w/ using a 2 bolt in a performance application.With good bolts or studs,your good to 500+ horsepower.
$75 isn't a bad price,as long as the guy will make good on the money if the machine shop tells you it's junk.
Old May 31, 2006 | 06:56 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Nothing good or bad about the particular block.
As a street use machine which isnt going to see 1000Hp a 2bolt is PLENTY strong enough. A 4bolt is not at all much stronger than the 2bolt block but it does keep the crank from walking.
If you want a bulletproof block get that 2bolt splayed to 4. But it is totally unneccesary in a street use application not to mention the cost of machining.
Its a good buy so long as their is no major damage to the block. It will most likely need to be align honed and bored before you can do anything with it though.
five7kid's Avatar
Transmission: 4L80E/4L80E
People were making a lot more than 400 HP on factory 2-bolt main, small journal SBC's before 1968. Of course, those cranks were steel, but the mains were all 2-bolt.
I 2nd Irocz's recommendation.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
cstrobel65
Aug 15, 2015 10:19 AM
fonzie85
Aug 13, 2015 11:50 AM
slade5612
Aug 11, 2015 07:19 PM
squiggy2
Aug 9, 2015 09:30 PM
