305TBI-350 CARB'D IN 91 CAMARO, SENSORS? GAUGES?
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
im planing on switching out my 305tbi to a 350 carbed. its a 91 camaro so it has the newer style gauge cluster. i want all my gauges to work liek they do now.just with the bigger engine. would it be easier to just find a cheap camaro around with a bad carbed engine or is it easy enough to do it on mine? any input would be appreciated thanx
Transmission: 4L80E/4L80E
As long as all you disconnect are the things associated with the computer controls, your gages will work as before.
I have a 1991 Camaro and we took the TBI off and when carb I have the water temp adn alt gauges work but the other ones do not. it is a T-5 and we put a 385 Stroker in it. we are using the stock fuel pump with a regulator. Any HELP WOULD BE GREAT. I hAVE NO TACH, SPEEDO, OIL , FUEL gauge. PLEASE HELP. My check engine light will flash and the gauges seem like they want to pop up but they do not go on. THANKS
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
