vats problems
Old Jun 5, 2006 | 10:26 PM
pontiacmo89's Avatar
Car: 89 pontiac firebird
Engine: 355HO 495 horse
Axle/Gears: 3:88
vats problems
i have a 89 firebird I did an engine swap on. it had a 2.8. I put in a 355HO heavily modified. i built the engine, put it in the car, got it all ready and then found out that I had missplaced my keys. IT has VATS. I called the GM dealership, gave them the VIN and they told me that anything earlier then 90 GM has destroyed the records for. I can't get the key codes the resistor values nothing. big help huh!!! anyway I was thinking about trying to solder in a resistor leading into the vats module to bypass the system. I was curious if anyone has done this or Knows if it works????
I also have a 86 trans am 305HO for a parts car, and i was wondering if I can take the ECM out of it and switch it with my 89 ECM. Then just cut the Vats completly out, since the 86 models weren't equipt with vats???
IF ANYONE CAN HELP ME FIGURE THIS ONE OUT IT WOULD BE GREATLY APPRECEATED!!!!!! THANKS
Old Jun 6, 2006 | 07:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
check out this web page:
12 Volt wholesale car alarm and car audio accessories
and this tech article:
https://www.thirdgen.org/vats
Old Jun 18, 2006 | 02:07 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
My son's '91 RS has/had VATS and the steering column was broken when we got it. We put an '88 Formula steering wheel in it, he got a chip from an earlier TBI 305 (prior to VATS) and we "permanently engaged" the relay just behind the kick panel on the driver's side floor. No issues since. You'd never know it ever had VATS.
You can do any of things we did, but I don't know if it will work if you don't do all of them.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
