Engine swap , EGR solenoid question
Old Jun 12, 2006 | 05:20 AM
techno101's Avatar
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
I swapped out the tired L03 for a new L98 setup( SPeed Density). My question is this.....On the back of the EGR Solenoid, there is a vacuum port. Where does it come from? I know that one line goes to the throttle body unit, and the other line goes to the EGR Valve, but I'm not sure where the back port goes to. Thanks-
Old Jun 12, 2006 | 10:24 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
It doesn't go anywhere, it is just a vent, should have a piece of foam on it.
Old Jun 12, 2006 | 04:42 PM
techno101's Avatar
Car: 1989 Camaro RS
well that makes it easy then! Thanks! So let me get this staight, There should be a vacuum line from the Solenoid to the EGR Valve, and a vacuum line from the solenoid to the Throttle Body or can it go to the underside of the plenum?
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
