383 and oil pan questions
Car: 1989 camaro
ok so i have a stock pan that i can use that will work in order to replace the 7qt summit pan thats on the engine. but will the stock one work without and clearance issues
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Far as I know, it should, as long as it matches the block you are using (dipstick on the same side, etc).
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
