V6 to v8 swap question
Car: 2008 silverado
Engine: 5.3
Hey i have a 92 3.1 RS that im going to be dropping a mild carburated 350 into. it has a t-5 now and i just want to buy a new bellhousing and clutch, and flywheel, and put the t-5 behind the v8, my only question is i believe the input shaft is like a 10 spline im not sure, but all the v8 clutches are 26 spline? What can i do? The reason i want to keep the trans is because i believe it is a worldclass one because it has the black blocking rings, and i just rebuilt it. Is there anyhting i can do about this?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
The trans does not fit a V-8 bellhousing if it is from the 6
Transmission: 4L80E/4L80E
Even if it is WC, the V6 trans is going to be weaker than the V8 version. The input shaft has fewer splines because it is a smaller diameter. You aren't going to find a clutch disk that is both the same spline as the V6 trans and same diameter as the V8 disk. People have reported having a custom disk made up for them that accomplished that, but is it really worth it to accomodate a weaker link?
Dump the V6 T5 and get the right thing (which arguably is a T56. . .).
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
i am sure you will do the right thing and get a v8 26 spline tranny... they run the same price as the V6's
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If you're really intending to reuse that transmission, then Summit sells a clutch disc for S10 V8swaps that utilizes the V6 input shaft, while maintaining V8 diameter. Check for it at summitracing.com
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Moderator editing of inappropriate comments.
QTA is on the right track as far as the disc : Advance Adapters Conversion Clutch Discs for S10 V8: ADD-716104 - summitracing.com
Thats the disc you need, its the correct diameter for the stock thirdgen V8 clutch, and the correct 1" 14 spline for the V6 trans.
You will need a V8 bellhousing, clutch fork, clutch cover, and flywheel, and more than likely need to grind a small bit off the front of the pilot on the input shaft.
Though I wouldnt plan on doing any racing on slicks or putting a 500 HP engine in front of one, in reality if you want to get a decent engine in there and know you'll be upgrading the trans when you have the money, you'll do just fine so long as your engine / driving are reasonable.
Car: GTA
Engine: 383 HSR
Car: 93 240SX
Engine: LQ9
Originally Posted by nelapse
The V6 Transmission has 16 splines.
No, as I posted, it is a 1" diameter 14 spline.
Car: 1986 Firebird
Engine: 3.4 outa 95' bird
Axle/Gears: 3.42 open rear
look up any replacement clutch for a v6 T5, they are all 14 spline, like the spec clutch sitting next to the 14 spline t5 in my basement...
Car: 93 240SX
Engine: LQ9
i would like to see this 14 spline manual transmission... if it exists.
Car: GTA
Engine: 383 HSR
I went to autozone.com, yes you were right. Now you can sleep at night with the satisfaction that for once you knew something. I retract all my previous statements.
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
isn't the bellhousing to transmission pattern in more of an "A" shape on the V6 and more of an "I" shape on the V8?
Car: 93 240SX
Engine: LQ9
They are exactly the same, the V6 T5 bolts right up to the V8 bellhousing with no changes.
