GM Perf. Plus vs. Edelbrock
Old Jul 31, 2006 | 01:49 PM
19IrocZ87's Avatar
ok guys, I have an old and tired LG4. Time to put her to bed. I've been working hard and saving my pennies for a crate engine to revive my Iroc. I've done research on both and am still confused with which one to go with. If I had the skills I'd build my own but I don't so crate it is. I'm looking for 350-400HP. Any input on which engine to go with would be greatly appreciated.
Old Aug 3, 2006 | 09:55 AM
big_man82's Avatar
Car: 84 rans Am
there is one at Blueprint Engines.com: Custom Crate Motors - Stroker Engines - Stroker Motors
that seems good for the money or you can try www.goautocenter.com
Old Aug 3, 2006 | 03:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1987-1992 CHEVY 350 / 5.7 ENGINE - CHEVY ENGINES 87-92
To the sale price add the core charge, shipping charge (probably around $300), and fork lift fee. You'll have to use your existing tin (oil pan, valve covers, etc.), and rear main seal carrier. Be sure to tell them you want 083 casting heads. They'll upgrade the cam for you as well.
Old Aug 7, 2006 | 03:38 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
do you want injection or carb?
Old Aug 7, 2006 | 04:16 PM
19IrocZ87's Avatar
I've had carbs for years, plus I love the way the 4 barrel sounds when you jump on it, so I'm staying carb!!!
Old Aug 8, 2006 | 03:19 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
id vote for GMPP, seems like you get more hp for the money. im not a big fan of edelbrock parts anyway.
Old Aug 8, 2006 | 03:40 PM
19IrocZ87's Avatar
You know, I have an Edelbrock carb, I gotta admit, I love the thing, but myself I'm starting to lean towards the GMPP engine. Personally, I've had no probs with Edelbrock, but, just like you said, it seems like you're paying alot more money for the same HP.
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
I have the zz4 and love it but why not go with the 383HT or zz383. 425hp and 460ftlbs sounds really nice.You could do the 383HT and do a cam swap.At some point the zz4 will feel slow once you get used to it.Start off with more cubes.Also GM has the 383 shortblock as well.
Old Aug 8, 2006 | 03:45 PM
19IrocZ87's Avatar
Tell ya' the truth, I was looking at those engines....Change the *** end and drop in some sub frame connectors and hold on!!!!
Old Aug 9, 2006 | 11:16 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
and trans,rear and susp. upgrades
PS i have not had troubles with edelbrock just that i know people that have had edelbrock AND others on the same engine (for intakes and carbs) and the others gave better times.
Old Aug 10, 2006 | 05:44 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
edelbrock is horribly overpriced, GMPP for the win
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
