305 to 454 questions
Car: 92 camaro rs
Engine: 305 tbi
Axle/Gears: 323 std
how hard is this to do and will my 700r4 work with it?
i need to know what i will have to change to make it fit, header clearence, will it require new suspension ect. i have a 454 lined up to buy but i dont know how much work is going to be required so im just asking for a little help
thanks
thanks
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its not a completely bolt in deal there is quite a bit of work required, the motor weighs morer that a 305 so the suspenson should be upgraded, the tranny will have to be beefed up, as with the rest of the drive train, you can get bb swap headers from summit and jegs, i belive they are long tube... its definatly doable and would be cool
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
there is a sticky on this section of the board for BBC swaps. i'd read that first.
Fast355
Dec 2, 2016 06:33 PM
