94-96 LT1 ?s
Old Sep 24, 2006 | 07:52 PM
iceman117's Avatar
94-96 LT1 ?s
ok my fathers got this 94 lt1 Vette motor in his 31 chevy that jus sh*t the bed... we got this 96 camaro lt1 to take its place. our question is... do you need to change computers, and we also want to change from the TH400 to a 700R4 so we need a kickdown throttle body. we have a few TBs also lol so here r the pictures.
1994 vette TB
1996 Camaro TB
BBK 94-97 TB
those connections on the BBK TB... which one is the kickdown connection and can u even use that TB??
THANX
Old Sep 24, 2006 | 08:42 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
So... what does this have to do with 3rd gen Camaro and firebirds?
Old Sep 24, 2006 | 08:49 PM
tpi-hearse's Avatar
Car: 1989 Iroc, 1987and 1989 formula 350
Engine: 305tpi,350tpi,ls1
Transmission: 700r4,t-56
Axle/Gears: 3:08,3:27,3:23
1994 vette TB
1996 Camaro TB
BBK 94-97 TB
THANX
1996 lt1s are odb2 cars are pre 96 odb1 cars...
Old Sep 24, 2006 | 08:56 PM
iceman117's Avatar
sorry confused with the generations duuuhhhhhhhh im an idiot.... i became a member of third gen dot org cuz i bought a 3rd gen a while back and got rid of it. i havemt done much with camaros the past few years so i i forgot sorry.
but is there ne1 that could possibly answer my question... or mayb direct me in the right direction?
thanx
Old Sep 24, 2006 | 09:07 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Call a place that sells used LT1 engines and ask them. They will probably be able to help and sell you any needed hardware.
Old Sep 27, 2006 | 12:17 AM
Firebat's Avatar
1st pic is a 94-97 style without cruise control, 2nd is 94-97 style with cruise control, 3rd pic is 93 style but can work with 94-97's. The 93 has the extra tab for the TV cable for the 93 non-computer 4l60 transmission. On the third pic(BBK) the top one tab is where you would connect the tv cable.
Keep the 94 LT1 computer, 94-95 is obdi and is easier to program and with a tune will yield about 10 more hp over the 96-97 computer with the same engine.
And read the info on this link for 700R4 with 94-up LT1:
https://www.thirdgen.org/forums/ltx-...ml#post3067214
Old Sep 27, 2006 | 10:42 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Ah from one car fan to another we need to help each other out. Rules are meant to be broken J/K
Seriously .. i would just slap that engine in ... swap over the pcm and harnness and call it a day. you really only need the lt1 long block anyway from the sounds of it.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
