LT1/700R4
Old Aug 7, 2006 | 12:49 PM
jjohnston's Avatar
Car: 91 Camaro RS
LT1/700R4
Ok, I've done some searching and it sounds like I either need bracket from the 93 Z28 or I need a whole TB from a 93? Which is it, my engine came out of a 97 Trans AM.
Old Aug 7, 2006 | 07:52 PM
Firebat's Avatar
search for my replies from me on this subject. You need a 93 throttle bracket. You need a 93 tv cable. You need a 93 throttle body OR a have a stud bolted to your tb. Holley makes a stud kit for about $6, this holley part can be found at o'reileys. You need a 4l60e vss and reluctor and you need to install the vss and reluctor on the tranny. Also need a TCI lock-up kit for a 700r4, can be bought through summitracing.com
Old Aug 7, 2006 | 09:19 PM
ssean92's Avatar
Car: sold
hey bud did you ever get this to work well????? as u know i kinda gave up on it and went with the t56. i know u were heading in the right direction
Old Aug 8, 2006 | 12:11 AM
Firebat's Avatar
Oh yes, it works. The LT1 still has a knock retard problem though, I even changed the opti, after months of looking over about everything - probably just going to end up zero-ing out the knock sensor. The car runs great otherwise.
One extra step I might take is to put in a 93 4l60 governor in the 700r4 tranny. I have to research that more though but I think that governor will let it shift at a higher rpm at WOT. Right now at WOT I think the shifts are around 5600 rpm.
Old Aug 8, 2006 | 07:12 AM
ssean92's Avatar
Car: sold
good to hear, what knock module u useing i was getting the same thing till i changed to the lt4 module, have u tried that?
Old Aug 8, 2006 | 08:31 AM
jjohnston's Avatar
Car: 91 Camaro RS
Ok, what does all that stuff cost, and how hard is it to install? Would I be better off getting a manual trans from a 97? What is the trans model on the 97 manual? Can I avoid all the vss kit etc by getting a 93 TB or would I need that either way?
Old Aug 8, 2006 | 11:40 AM
Firebat's Avatar
you need all the things mentioned in post #2.
quick estimates-
93 Tb bracket - $13
93 TB brand new - $250-300 OR Holley Stud Kit - $6
93 TV cable - $20
95 4l60e VSS and Reluctor - $30???
TCI Lock up kit for 700r4 - $76
How difficult to install? The last two above will be hard to do. Pound off your old speedometer reluctor and pound on the 4l60e one. I also figured out a way to add a relay to the tci kit circuit so I didn't even have to drop the transmission pan. Out of that whole $76 kit, I'm only using the vacuum switch.
I do recommend the T56 over the 700R4. The only reasons I kept my 700R4 was that the tranny was rebuilt and I got the tranny for almost nothing. I will put in a T56 someday.
Old Aug 8, 2006 | 01:21 PM
ssean92's Avatar
Car: sold
i will say the t56 is a much better option if you can float it
Old Aug 18, 2006 | 10:19 PM
jjohnston's Avatar
Car: 91 Camaro RS
problem with the t56 is its a manual. I would think it would be crazy hard to convert my auto to a manual... Maybe I should just get a 4l60e and call it done, save the headach of installing the vss kit and things. then all I would need is the tv cable. right...
Old Aug 18, 2006 | 10:21 PM
Firebat's Avatar
yeah, but a lot of people on this website have done the t56 swap. Its documented pretty good I think. Its not like you would be totally in the dark. I'm looking into the T56 because I think it would be smarter in the long run. Example: Blow out 2nd gear in an auto and you have to have the whole tranny redone, blow out 2nd gear in a manual - just replace that gear. Another example: my brother went through 3 4l60e's in 3 months with a stock LT1, and 2 of the 4l60e's were rebuilt.
Old Aug 19, 2006 | 04:53 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
The auto to manual conversion is easier done than it looks. 4th gen pedal assembly, cut the hole in the floorboard, bore the hole for the master cylinder and get a Spohn T56 swap crossmember and that's it.
And if your motor is a '97....save yourself a headache and do the OBDI swap on it.
Old Aug 19, 2006 | 06:28 PM
ssean92's Avatar
Car: sold
i did the auto to manual t56 swap and it was pretty easy well worth it
Old Aug 20, 2006 | 08:17 PM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Can you throw a T56 on a gen 1?
Old Aug 20, 2006 | 09:28 PM
Klortho's Avatar
Car: 1987 GTA
Yup, it's the same bellhousing boltup as a T5, 700R4, 350 Turbo.
Although I wouldn't want to throw it on a Gen 1, might cause some damage, dent up some fenders etc etc.
Old Aug 20, 2006 | 11:10 PM
r0nin89's Avatar
How might I ask?
Old Aug 20, 2006 | 11:49 PM
Firebat's Avatar
by literally throwing it
Old Aug 25, 2006 | 07:51 PM
jjohnston's Avatar
Car: 91 Camaro RS
Ok to make my 700r4 work I need a tb bracket. I found 2 and they both look different. below are the links. which one is the right one... or can someone give a link to the right one??
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 20, 2006 | 11:27 PM
Firebat's Avatar
Lokar Throttle Cable Brackets: LOK-TCB-40LT1 - summitracing.com
Lokar Throttle Cable Brackets: LOK-TCB40TP1 - summitracing.com
don't buy aftermarket, get the 93 bracket from your local GM parts dealer
Old Oct 5, 2006 | 10:03 AM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
1. is this kit needed for use with a 700r4 behind a '93 LT1?
2. if so, wouldn't it be possible to make it yourself with the right supplies using only a vacuum switch?
Old Oct 5, 2006 | 10:29 AM
Firebat's Avatar
1. No, the 93 LT1 with the 93 computer won't need it.
2. Yes, all I'm using from the Kit is the vacuum switch. Then I wired up a relay to do the same function as the part they supplied to go into the 700r4. I'll try to find the vac switch just by itself, through an electronic parts supplier, to save money for everyone else in the future.
Old Oct 5, 2006 | 11:19 AM
Firebat's Avatar
The vac pressure switch is World Magnetics PSF101. Its kind of wierd part. I'm not seeing any electronic distributors have it, it has to be ordered directly from World Magnetics.
You start by going to their site for the part:
http://www.designflexswitches.com
http://www.designflexswitches.com/ps...ring_Guide.htm
Want part no. 8061-???, and thats all I know. You would have to call them and tell them you want 8-10Hg for pressure. I dont know if they would even bother to make just one though.
Old Oct 5, 2006 | 12:16 PM
eagle_eyes's Avatar
Engine: '93 LT1
thanks for the research...that should help for future references
Old Feb 7, 2007 | 08:01 PM
zmack28's Avatar
VERT to a OBD1
I am putting a LT1 in a 89 camaro that had a 305 TBI in it. I am buying the parts now to complete the swap. I read in this thread that it is better to change to OBD1 instead of OBD2. Which is more cost effective and easier to do? SO far all i have is the computer out of a 97 Z28 LT1. Im looking to get a harness, been watching ebay. but its unclear which way i should go with this......any help will be greatly used. Thanks
Old Feb 7, 2007 | 09:36 PM
Firebat's Avatar
Obdi. If you start having problems, you can get a scanner program for your pc, hook your pc up to the LT1 PCM and see what the sensors are doing. Cables cost $90, $45 if you build them yourself but not recommended unless you can solder as good as an electronics technician like me. Email tunes cost $60, Tunercat for OBDI i think costs around $100 but you should still be able to get a free trial. TTS datamaster(scanner program) costs $200 but there is a trial version available. OBDII prices for this stuff cost a lot more and i'm not even sure if scanner programs exist for obdii LT1's.
If you don't want to program yourself, you can send your pcm to madz28.com or pcm4less.com and they will program/tune it for around $100. You have to send it through the mail.
Old Mar 14, 2011 | 10:39 PM
92last1rs's Avatar
Re: LT1/700R4
I have a 1992 camaro with the 5.0li TBI and I also have a lt1 motor out of a 95 caprice police packageand i have a few questions.Should the ODB 1 system should work with lets say a LT1 out of a 95 Caprice Police Package? Also, what do i need so i can use my 700R4 trans with the lt1 from the 95 caprice police package motor. If anyone is an expert or has done it I could really use some advice.
Old Mar 15, 2011 | 04:37 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1/700R4
This is what you will need to get the 700R4 to work.
In the end you would better off finding a 4l60E for it. And the OBD 1 will work with the 95
Old Sep 3, 2012 | 02:38 AM
cschaffner's Avatar
Car: 1987 Iroc-Z28
Engine: L98 (soon to be LT1)
Transmission: 700R4 (soon to be 4L60e)
Axle/Gears: 3.27 LS
Re: LT1/700R4
Old thread, I know, But is it really necessary to put a 4l60e relucter/sensor in my 700R4 to use it with my LT1? I'm going to be using a mechanical speedo.
My LT1 is out of a 97 bird with a t56. so the pcm is programed for that.
Old Feb 14, 2013 | 07:49 AM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
Re: LT1/700R4
Even more interesting. I am putting an LT1 into my 84 Z28. It was origionally in a T56 car (for the LT1, my car has a 700R4), so there is no provision for the electronic TCI kit whatsoever. Can I simply use the 93 t/v and bracket to make it run? I can still add the VSS if needed, but I will probably keep my OE gauges. Can the LT1 w/700r4 work without the TCI and VSS?
Old Feb 6, 2016 | 08:11 PM
GFusick's Avatar
Re: LT1/700R4
can you answer my question what is he stud kit is it just stud for he kick down cable ?
LT4Hawk9
Feb 28, 2008 01:28 PM
92Forumla
Dec 29, 2007 11:40 AM
