1990 Camaro fuel injected v6 to carbed v8 swap
Old Oct 5, 2006 | 11:25 AM
BigAL1990cam's Avatar
Car: 1990 Camaro RS and 1987 PowerRam150
Engine: 3.1 v6 & 5.2 v8
Transmission: auto.
Axle/Gears: limited slip, 3.70
Hey all you guys, i have a question
i have a 1990 Camaro RS with a fuel injected 3.1 Liter v6 and i am going to swap it with a 5.7 Liter 350 because my motor is blown, so i was wondering if anyone knows anything about what i will have to change, i was hearing i might have to change the hood to a cowl induction, if i could i dont want to and all of the fuel pump situations, what do i have to do and what would be the right way to go about doing it
thanks
Old Oct 5, 2006 | 12:13 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
What I did when I went from FI to carbed is pull the tank and replace the pick-up with a carbed pick up. This is allows you to simplify the lines and related hardware. I run a Edelbrock Performer mechanical pump and it works fine. Make sure you cut the electrical lines to your existing pick up as you will graft them to the carbed p/u, if you choose that route.
You'll need springs from a V8. The bolt holes to mount V8 frame mounts already exist on your frame. I believe there is no change to the tranny mount and driveshaft...you'll have to verify that.
You'll have to round up a regular carbed HEI for a V8. Would probably make life easier if you could round up an electrical schematic for your car. You'll have a hot wire from your existing distributor that you'll be reusing as well as reusing your tach wire.
Old Oct 5, 2006 | 03:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Most of what you're asking is addressed in the V6 to V8 sticky at the the top of this forum.
Old Oct 13, 2006 | 07:12 AM
Transmission: auto.
thanks for all of the help guys if you think of anything else let me know
RedLeader289
May 28, 2019 01:47 PM
customblackbird
Oct 1, 2015 04:30 PM
BLK87Z
Sep 18, 2015 11:29 PM
Roxtar69
Sep 15, 2015 05:24 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
