Motor help
Old Oct 7, 2006 | 10:26 AM
youngmiguel's Avatar
Car: Trans Am
Engine: 305 TBI
Motor help
i blew my head gasket and putting a used 305tbi motor in my trans am, which was a 305tbi. the only motors at most of the junkyards have came out of chevy caprices, vans, and trucks. i just want to know what mods or changes do i need to do, in order to get the motor to work correctly if anyone can help?
Old Oct 7, 2006 | 12:16 PM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
If you are swapping a 305 for a 305, wouldn't it be easier to just change the Head Gasket?
Old Oct 7, 2006 | 12:21 PM
Car: Trans Am
Engine: 305 TBI
yeah but i ws told that i was gone have to get my heads checked for cracks at a machine shop and plus laborwise it was going be more expensive. and i can get a used motor for cheaper with installation.
Old Oct 7, 2006 | 12:53 PM
350IROC1989's Avatar
Car: 1989 Camaro Iroc Z
Engine: GM Goodwrench 350
Transmission: T-5 Manual
As long as you didn't run the car for an extended period of time while over-heating, you shouldn't have a problem. I don't believe your motor had aluminum heads, but I could be wrong. Someone correct me if so.
You can basically visually inspect it for cracks, I've blown plenty of head gaskets, checked for cracks, put it back together and ran fine. You need to worry about warping more than cracking, and even still it's unlikely unless you ran the engine while it was over-heating.
Old Oct 7, 2006 | 01:12 PM
Car: Trans Am
Engine: 305 TBI
i cut back since then on driving it. i just need know whats the best way to go. i was just told by a couple shops that i'm gone have to send my heads to a machine shop for cracks and warping which i forgot to mention.
i just know that the labor was gone get in my pockets
Old Oct 7, 2006 | 02:49 PM
If your head gasket is blown, you shouldn't be driving it at all... not just cutting back. You're talking long-term damage down the road.
Old Oct 7, 2006 | 03:02 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
Did coolant leak out of the engine, or into the engine?
If it went in and your oil looks like a milkshake, and you've driven it, the life expectancy of your engine has been greatly reduced. So a used engine might be a better idea, but could also be worse.
Old Oct 7, 2006 | 03:50 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Well I dont know about machine shops in Ohio but having the heads checked and all that stuff would be $50-100 and here if they turn out bad 9 times out of 10 they won't charge you nothing. If you need a 305 pm me I have a 305 tbi in a 92 camaro.
Old Oct 12, 2006 | 11:46 AM
Swim500in5's Avatar
Car: 83 Z-28
Engine: 305 Qjet
Transmission: 700r-4
easy fixer for more power
get a used 350 from a truck, put a new cam in it and drive it stock will be faster than what you have now. and will still work with the TBI just run your tbi rich and it should make ok power with the 350
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
