tpi swap
Old Oct 8, 2006 | 09:01 AM
chevrunner21's Avatar
Car: 1992 trans am
Engine: 305 tpi
tpi swap
i've got a 1992 trans am 305tpi 5spd trans, and i wanted to rebuild a 350 bottom end and bolt the tpi stuff on to the 350. and what do i do about the computer, i know i can't just have the computer tuned i have to get a chip made and plug it in, could you give me more info on the whole computer issue and putting the tpi parts on the 350?
Old Oct 8, 2006 | 10:25 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
You will need a memcal for a 350(I used one for a vette), injectors and knock sensor for a 350 and that should do it. I hope you are not going to reuse the 305 heads. They are good heads, but they will raise your compression ratio a lot. I have done this swap in a 91 Formula and I had no problems.
Old Oct 8, 2006 | 02:51 PM
Car: 1992 trans am
Engine: 305 tpi
memcal?? whats a memcal? i would like to use the 305 heads until i got the money for some aluminum heads. how much will the 305 heads raise my compression?
Old Oct 8, 2006 | 03:08 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
The memcal is the little blue "chip" in the ecm. It holds the program for your setup. They are specific to 305 or 350. I think the 305 will give you something close to 10.5:1. You also need to be careful with cam choice. TPI setups can only handle so much cam without a lot of custom programming.
Old Oct 8, 2006 | 03:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If you are building a new 350 bottom end, then use the 305 heads. Just choose pistons with having 58cc chambers in mind, instead of 64cc. Not a big deal.
Old Oct 8, 2006 | 06:03 PM
Car: 1992 trans am
Engine: 305 tpi
i was thinking about getting one of those custom made chips where i tell the company exactly what i have done and they program the chip specifically for my setup any information on those? or oppinions?
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
