tbi to tpi swap problem - injectors
Car: GTA 89
Transmission: TH700
Axle/Gears: BW 9 bolt
Hi
I have a problem with engine swap. One my car has 305 TBI (formula, 1989 year) another one has 350 TPI (trans am, 1989 too). I swap motor and whole eng. harness to formula. I left in place interior and light harnesses.
Everything is ok except injectors - exactly they won't fire. I think it may be a VATS problem because SECURITY lamp stay on when I turn the ign. switch, but sometimes lamp is going off and the inj. still won't fire...can anyone help?
thanks in advance
thanks in advance
Transmission: 4L80E/4L80E
Okay, a dumb question first: Did you change the computer as well?
