cooling help after 305tbi to carb'd 383 swap
Old Oct 8, 2006 | 05:50 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
my car was originally a 305tbi. i put a 180* thermostat and fan switch in. i reciently picked up a 383 and im really confused on the cooling system. its going to be carbed. the intake manifold has a hole for an aftermarket cooling sensor the guy told me im just lost on what to do. should i put my 180* thermostat back in? and do i even need the 180* fan switch anymore? any help would be apreciated thanx
Old Oct 8, 2006 | 07:18 PM
redlsone's Avatar
What I did was used the one hole for a digital aftermarket gauge,plug the other hole and picked up a set of dual fans to run all the time and havent had a problem since.
Old Oct 8, 2006 | 08:14 PM
spills's Avatar
Car: 89 RS
Engine: 6.3L Megasquirted HSR
Axle/Gears: 3.70 Posi 9 bolt
I used the hole on the front of my edelbrock manifold for my temp gauge (autometer), and the hold on the driver side head for my elec. fan switch. Before I had the elec. fan switch, I bought an adjustable fan switch thingy that still worked pretty well. Im running a 190 thermo and I havent had any problems so far
Old Oct 8, 2006 | 09:19 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
thanks guys just what i needed
midge54
Jan 29, 2017 07:00 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
theurge
Aug 21, 2015 12:46 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
sreZ28
Aug 14, 2015 07:48 PM
