New 350?
Old Oct 10, 2006 | 11:47 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
New 350?
Im looking to replace the TPI 305 with a New Crate 350, what is a popular engine, and does anyone have estimates on price and time?
Old Oct 11, 2006 | 01:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you planning on doing the work, or having a shop do it? Makes a big difference in any price or time estimates.
Here's a pretty decent package if you want to keep the TPI and want good power 360 HP TPI Vortec Custom High Performance Series Street and Strip Engine :: SD360VTPI - SDPC . You'll need headers, aftermarket runners, 22 lb injectors, and larger TB to get the power they advertise.
If all you're looking for is a basic 350, a lot of people have gone with this one 290HP / 350 Long Block Pre-Emissions GM Crate Engine :: 12499529 - SDPC . TPI would knock the stated power down slightly.
Old Oct 11, 2006 | 04:36 PM
plndtx's Avatar
Car: '92 Heritage Z28 Convertible
I'm eyeing the Golen 405hp /492 tq 383.
Keep in mind that if you get an engine with vortec heads, you are going to have to modify the headers/manifold for the EGR intake tube.
Chevy Fuel Injected Custom Built Performance Engines!
Old Oct 11, 2006 | 07:16 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
well im just looking for a 350, so i think the 290hp 350 will do the trick. plus im working on a small budget so nothing too special. and im planning on doing the work myself any price estimates, thanks
Old Oct 11, 2006 | 11:04 PM
five7kid's Avatar
The 290 horse Goodwrench engine has the '86-earlier intake mount bolt pattern so you'll have to elongate the center two bolt holes on each side to get the TPI base to fit. Or, try to trade someone yours for an '86-earlier version.
It also has the '85-earlier 2-piece rear main seal, which uses a different flexplate than you've got. About $20 for a new Pioneer one from the chain parts stores.
Other than that, you'll need intake and water pump gaskets (~$50 or less), and 350 knock sensor and module (about $100-$130 or so).
There's also this engine 1991-93 Chevrolet, Cadillac B & D (L05)(5.7K) :: 12513151 - SDPC . Your base and flexplate would bolt right to it, and it has a roller lifter cam in it (unless it's a rebuilt, in which case it will have a flat tappet cam in it). You'd still need the gaskets and knock sensor & module.
Old Oct 13, 2006 | 10:10 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
The only thing to consider about that engine....it that the L05 heads are absolute garbage, as is the cam. It would probably run like his existing 305...if not worse
Old Oct 14, 2006 | 12:19 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
so ive been looking around, and i think i wanna go 383 rather then a 350. Time to start savin pennies
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
