I'm about to make my swap...what am I forgetting?
Old Nov 1, 2006 | 12:38 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Going from a TPI 5.0F to a TPI 5.7, T5.
Going to use Edelbrock E-200 heads, vortec intake, ported SLP runners and plenum, 22lb injectors, disable my
EGR, base motor is an L31 vortec, cam is a Comp Cams XR276HR, with 1.6 CC magnum rollers, Hooker 2210's,
etc. Obviously, I'll have to do a custom chip, but I'm getting a 5.7 knock sensor, and a 5.7 ESC module. I'm also
using a Holley AFPR. What am I forgetting?
Old Nov 1, 2006 | 06:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
reusing starter from T5? I guess that block is drilled for it.
Got a damper (one from 305 or 350?)
Got a flywheel (reuse old one?)?
Sounds like you got most everything. Heads are assembled? Got roller lifters and pushrods?
Old Nov 1, 2006 | 08:53 PM
'Shifter's Avatar
Car: 87 Z-28
Dampner....I'd like to run a TCI or Fluiddampner, but which model? Fluiddampner doesn't answer their e-mails...would I get one for the 98+
chevy truck, since that's what this replacement motor allegedly fits?
Old Nov 1, 2006 | 10:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
You get one for a 350. An 8" generally.
I think the only thing that every changed on dampners is with the LS1 (I just checked summit, that appears to be the consensus). So they show '96 and newer as using an LS1 dampner. Your Vortec 350 isn't an LS1 as far as I know. But I don't know squat about newer motors.
Old Nov 2, 2006 | 10:30 AM
'Shifter's Avatar
Car: 87 Z-28
I didn't know if because it's externally balanced, because it's a one-piece rear main, that the balancer would be different....
3rd gen money
Sep 8, 2015 11:40 PM
backtothe80s
Sep 5, 2015 12:39 AM
cougar20th
Aug 27, 2015 08:04 AM
z28addict8490
Aug 7, 2015 08:48 PM
