305tbi engine swap
Old Nov 4, 2006 | 06:32 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
305tbi engine swap
what motors can i "drop in"(NO FABRICATION, NO MODIFICATIONS, Just pull out the old, drop in and bolt up the new one)to my 91 camaro rs with a 305tbi? how about out of these?(if im forgetting one and itll work let me know) 305tpi?327?350tpi?383?396?427?454? Thanks for the help
Old Nov 4, 2006 | 09:15 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Well the big block will not just drop wright in. The TPI will have to change wiring,Mabey a 350 tbi will drop in with no modification.
Old Nov 4, 2006 | 09:53 PM
Car: 91 rs
Engine: 305tbi
thanks for the info
Old Nov 5, 2006 | 09:06 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
If you have throttle body injection and don't want to change anything wireing wise you are going to have to keep the 305 or possibly a 350 TBI engine you would probably want to upgrade the chip in your computer to the 350 one but it would run , otherwise any small or big block engine can be put into it but you would need mods to get it working like going to a carb and intake set up and changing the fuel system ...
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
armybyrd
Aug 10, 2015 09:23 PM
