New 350 to replace tired 305
Old Nov 5, 2006 | 12:44 PM
Drunkalunka's Avatar
Car: '92 RS 25th Anni
Engine: 305TBI
Well i'm planning on swapping my tired 305 for a new rebuilt 350 and was just posting here to see if anyone had any opinions or suggestions on better parts that i could use in the process. The block I'm going to rebuild is a 350 4 bolt main out of a early 90's p/u since those are readily available in my area (<3 Texas trucks).
Heads - Edelbrock Performer Aluminum Heads
SB-Chevy 302-400ci Performer Centerbolt Aluminum Cylinder Head
165cc Intake Ports
60cc Combustion Chambers
2.020'' Int/1.600'' Exh Valves
1.460'' Valve Springs, .575'' Max Lift
3/8'' Rocker Studs
Intake Manifold - Edelbrock Performer T.B.I. Intake Manifold
Cam - Edelbrock Performer-Plus Camshaft
Duration Advertised268° Intake/288° ExhaustDuration @ .050''194° Intake/214° ExhaustLift @ Valve.398'' Intake/.442'' ExhaustLift @ Cam.265'' Intake/.294'' ExhaustLobe Separation Angle112°Intake Centerline107°Intake Timing @ .050" Open 10° ATDC
Close 24° ABDCExhaust Timing @ .050" Open 44° BBDC
Close 10° BTDC
Throttle Body - Holly Pro-Jection Throttle Body
TBI Assembly
For 2-bbl Pro-Jection
670cfm
Any and all gems of wisdom would be greatly appreciated
Old Nov 5, 2006 | 01:00 PM
Parrydise7's Avatar
Since you are a newb, you may want to check out the search feature. This question comes up all the time.
What is your goal?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reborn756
Sep 4, 2015 03:42 AM
st.evel07
Aug 13, 2015 06:15 PM
Fronzizzle
Aug 9, 2015 01:15 PM
