305 or 350
Old Nov 11, 2006 | 06:05 PM
nick86bird''s Avatar
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
305 or 350
how do you tell the difference between a 305 and a 350?
Old Nov 12, 2006 | 12:14 AM
BlkBird408's Avatar
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
If the heads are on the engine you can get the block id number off the rear flange of the block where the tranny bolts up. Then call GM or a local machine shop and they can tell you what you have. If the heads are off you can measure across the cylinders. A 305 has a 3.735 bore and a 350 has a 4.000 bore.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
