Are all 305 TPI's Equal
Old Dec 10, 2006 | 06:54 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I am about to drop a 305 TPI in my 89. I'm told that the manual 305 makes more power (220hp) than the auto 305 (195 hp). WHY??
Old Dec 10, 2006 | 09:18 AM
rik89gta's Avatar
Car: 89 FORMULA 350
Engine: 5.7 L98
Axle/Gears: 9 BOLT/ 3.27 GEARS
The camshaft in the manual cars are much bigger. But, the 85 models with an automatic trans have the hotter cam too.There may also be some cylinder head variations among the 305 TPI's as well. But the cam is the biggest difference among the engines.
Old Dec 10, 2006 | 10:15 AM
mjustdie's Avatar
Car: 86 IROC, 04 Ram, 05 SRT-4, 95 CBR
Engine: LB9, 5.7 Hemi, 2.4 turbo, 600cc
Transmission: 700-R4
Axle/Gears: 26 spline 3.42's for now
look up the tech articles. the first (85) tpi 305 had something like 210-215 hp and they dropped down in 86. they gradually boosted them back up to 220 then by 92. during that duration there were a couple of cams they used in different vehicle. best thing to do is to just get a hotter cam anyway.
Old Dec 23, 2006 | 08:13 PM
mightymouseman's Avatar
Car: used to have red 1991 camaro RS
Engine: with 305 TBI
Transmission: Borg Warner T-5
Axle/Gears: and 3.08 open 10 bolt
go ahead and do a DCR calculation. that should tell you what cam you should run. bigger isn't always better, especially with smaller cubic inch engines. big cams bleed off cylinder pressure, which is where you develop your power from. take a look at the quench too. good luck.
Old Dec 23, 2006 | 11:45 PM
AJB-283's Avatar
Car: 89 RS
Engine: 383
Axle/Gears: 9 bolt 2.77
From my experience, go bigger the first time, don't have to do it over and over.
Old Jan 2, 2007 | 02:05 PM
92IrocRS's Avatar
Car: '92 RS ~ '92 Ranger
Engine: 305 TPI ~ 2.3 OHC
Transmission: 700R4 ~ Mazda 5-Speed
Axle/Gears: 10-bolt 3.23's ~ 7.5
All that power is lost through the torque converter
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
