Vortec Heads on L98 Block -
These will bolt right on right?
I am about to order a Stealth Ram setup for my 350. I noticed they make the Stealth Ram setup for Vortec heads now.
So my main question is will the vortec heads bolt right up to the Stock L98 block? Any known issues/suggestions?
Thanks.
Thanks.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the vortec heads will physically bolt onto any small block chevy engine. A search will find you more info if you need it.
thanks man. yeah, i've been reading for the past couple hours. is there a specific casting # set of heads that flow best or any vortec heads?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
906 or 062, but if you're buying them new i'd get RHS vortec heads they have a thicker casting deck and already setup for bigger springs, screw-in studs, etc
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
