What Heads would you Suggest??
Old Dec 24, 2006 | 10:04 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Just wondering what heads you think would work best with me rebuilding my L98 with the LT4 Hot Cam and including the mods in my sig? I want to stay with my intake so I want to stay away from Vortec/Fast burn heads. I was thinking maybe AFR195s any othe ideas?????????????
Old Dec 24, 2006 | 01:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A search didnt come up with anything?
Trick Flow 23 degree heads are the best bang for the buck. AFR 195's are better but are also a lot more expensive.
Old Dec 24, 2006 | 06:20 PM
zz4monte's Avatar
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
If you talk to AFR they will probably tell you to get the 180cc heads but if you ever upgrade to a 383 you could use the 195s.Not that the 195s won't work but when I called AFR they recommended the 180cc for almost all street driven cars under 383 cubes.They also told me that unless your running a bigger cam over 224duration in a 383 that the 180cc will only give up a 5-10hp and gain 30+ftlbs of torque.But yes the AFR heads 180cc or 195 are the best heads if you can afford them.I have seen guys drop almost a half a second of the 1/4mile times by just bolting them on.Doesn't mean this will happen for you but they are serious heads for a street car.
theshackle
Mar 5, 2017 06:37 PM
509 camaro fan
Sep 6, 2015 10:43 AM
NinjaNife
Aug 23, 2015 11:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
