Install engine with TPI intake, accessories, in place or not?
Old Jan 2, 2007 | 12:35 PM
Dr G's Avatar
Hi guys,
Does anyone have any stong opinions on whether the TPI Itake should be installed on the engine when it's out of the car? Or once it's back in?
How about the distributor? Front accessories like water pump etc?
Thanks,
Old Jan 2, 2007 | 12:50 PM
TexasLT1's Avatar
Car: '92 RS
leave the didtributor out so you don't smash it up getting the engine in, but I've always left the acc. on when pulling/installing an engine
Old Jan 3, 2007 | 02:36 PM
Firebat's Avatar
I damaged my window wiper motor sometime during the engine swap. It wouldn't be a bad idea to remove that too.
Old Jan 5, 2007 | 08:25 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I'd install the TPI and the distributor before you put the engine in. I wouldn't put the dist cap on until after it's bolted in. I'd leave the starter off and the front acessories........with the exception of the water pump.....if it's a manual trans, leave the bellhousing on, but not the gearbox.........that can be put on later from underneath..........that's been my lessons learned on the last few swaps.........others may have different preferences..........
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
86IROC112
Aug 17, 2015 02:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
