1986 motor mounts
Old Jan 6, 2007 | 06:20 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
1986 motor mounts
i'm talking about the solid mounts that bolt to the block here.
i have two different part #s now and was trying to figure out which is the correct one
one is 334971 (the 971 is much larger)
the other is 14039436 (the 436 is larger like the 971)
the second one has the lips that go over the rubber mount (where the long bolt goes thru) flared outward where the 334971 does not.
is one correct? does it matter? they seem very similar except for what i already noted.
thank's in advance!
Eric B
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
