How to remove bellhousing bolts?
Engine: LS1, LB9, L03
Having a helluva time trying to get out the top two bellhousing bolts that connect the wiring harness on the top of the transmission. I can see the passenger side one from under the car, but I can't see the driver's side at all. Is there an easy way to get these out? I've been trying to get them with a u-joint and a long extension from under the car, but I'm not having a lot of luck.
get an even longer extension. I seriously had about 2' of extension when I did it in the car. also, it will help if you get a jack under the tailhousing of the transmission and unbolt the crossmember, then let the jack down some, tiliting the engine/trans back. gives you more room to get to the top bolts. just have someone watching the engine compartment to make sure you don't crush anything.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
From experience, I'd say no. Patience is the key. I personally had no luck from above. I resorted to the extension/dropping-transmission-tail shaft method (be careful of the distributor and firewall) along with a profundity of obscene language that frightened the most stout hearted in the neighborhood.
JamesC
JamesC
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
I always drop the tail and use about 3' worth of extension and a u-joint myself. Pick up a 24" extension to go with whatever else you have. You'll be happier.
Car: '89 Formula
Engine: 355 SBC, AFR 195s
Transmission: T-56 Swap
Axle/Gears: 7.5 Eaton LSD w 4.10s
ya, in the end to get the top two bolts, you end up with your ratchet somewhere around the tranny crossmember, definately with at least one universal. i had every extension i owned to get mine out and back in last weekend.
Hmm...well I should be able to work something out now with all this knowledge. Thanks guys!
Transmission: 4L80E/4L80E
I've had the engine out three times: First, pulling the engine/transmission out of the donor car; second, pulling the 305 to do some go-fast upgrades; and third, to put in the 350 shortblock. The second time I pulled the engine only.
Based on my experience, whenever the topic comes up, "pull engine only, or engine/transmission together?", I always say, "Pull the engine and transmission together."
For the very reason of this thread topic.
Eric-86sc
Apr 3, 2016 03:52 PM
383backinblack
Aug 15, 2015 06:36 PM
