305 nto 350 vortec tbi swap
Car: 91 RS Camaro
Transmission: 5 Speed
Axle/Gears: 3:08
I had a 350 built to 300 horse and swaped it from my 305, when i drive it when its cold it runs great bout when it got hot the motor backed fired through the exhaust as load as a shotgun, when i put on the throttle in isdle position it chocked out and backed fired some more. after letting the car cool off for a few hours it stoped doing it till it got hot(200-220 degrees) could it be the fuel pump? the fuel filter was clogged i changed that, ..please help
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Here's an obvious question.Did you tune it?
Car: 91 RS Camaro
Axle/Gears: 3:08
305 to 350
well i changed out the distrib. to a new one, new fuel pump, filter,timed it before and after, the the results are the same bogging and a loss of horse power.i'm about to change out the wires and plugs but cross my fingers.
Car: 1990 RS
Engine: 305 tbi (currently)
Transmission: B/W 5spd
Car: 91 RS Camaro
Axle/Gears: 3:08
305 to 350 vortec
I changed the plug wires and found three of them were shorting out on the hedders. now it runs a lot better but i have to tune the computer now?
Car: 1983 G20 Chevy
Transmission: 4L60
Fast355
Dec 2, 2016 06:33 PM
then that is probably your problem and you should take a look at the Free Tune Sticky in the TBI section.
Happy Tuning
