ls1 or vortec heads
Old Feb 1, 2007 | 08:55 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
ls1 or vortec heads
i have a 87' 350 out of a trans am that was a tpi but i am converting it to carburation and want to put heads and a cam in it but im short on cash what would be the best buy (used heads)easiest swap and most power btw im pretty sure i have a flat tapped cam
Old Feb 1, 2007 | 09:42 AM
LS1 heads won't fit.
As far as heads, it doesn't matter whether the cam is a roller or not.
If you're short on cash, better to wait awhile, save up a bit, and do it when you can actually afford it. Beats starting a project and being unable to finish it because something unexpected happened; and then be stuck with a dysfunctional POS of some kind because you don't have the resources to deal with it. In other words, scrape up some money VOLUTNARILY while the car STILL WORKS, instead of being FORCED to scrape up some money while the car IS DISABLED.
Old Feb 1, 2007 | 10:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '87 TA 350 would have had a roller lifter cam from the factory. If you have a 350 out of an '87 TA and it has a flat tappet cam, either the cam or the engine was changed some time or another.
The heads of an '87 TA 350 have good performance potential. Do-it-yourself porting, aftermarket valve springs, and pinned or screw-in rocker studs will support a lot of power when properly matched with intake, cam, and exhaust.
Old Feb 1, 2007 | 08:48 PM
mxcrazed's Avatar
Engine: None
Transmission: none
well the car was a 350 5 speed so something was swapped
whee do i find the casting marks on the heads i think they have the 72deg bolt holes but i didnt see anything holding the lifters in i dont know where to start the engine was bored .30 over so its a 355 please help me id my engine thanks for you time
Old Feb 2, 2007 | 10:48 AM
five7kid's Avatar
The head casting #'s are under the valve covers between rockers. It would be a good idea to get the # off of each head.
While you're at it, the block casting # is behind the driver's side head, on top of the bell housing mount casting.
Get both, go to www.mortec.com, post here.
Old Feb 5, 2007 | 05:24 PM
mxcrazed's Avatar
Engine: None
Transmission: none
thanks for the help i found the one on the block before hadnt thought to pull the covers off for some reason
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
