Lifters in late model block
Car: 1989 Iroc Z L98
What solid roller lifters are you guys running in late model (hydraulic roller) blocks? I bought the Crane solid roller lifters and they did not even reach the camshaft lobes???
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
hmmm, hone the lifter bores, but the machine shop will do a better job
a little surface rust will kill you in the lifter bore.
Right; there's not too many of them that are tall enough for the link bars to clear the taller lifter bore in those blocks.
http://store.summitracing.com/partde...CCA%2D871%2D16
Also the 873, in a cutaway version.
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
you probaly got the retrofit version, not the ones meant for an oe block, here ya go
http://www.gmpartsdirect.com
PN 12371042
PN 12371042
Car: Camaro
Engine: Carbed L98
Transmission: TH350
PN 12371042
PN 12371042
Those look like Hydraulic roller lifter. He is looking for Solid Roller.
But yeah, those are for the stock Hydraulic roller blocks.
Street Lethal
Sep 7, 2015 01:09 PM
dimented24x7
Sep 6, 2015 03:51 PM
