91 305 TPI Motor into 91 305 TBI
Car: 1991 RS Camaro Convertible
Hi Guy's,
I've just purchased a complete 305 with tpi, harness,computer etc from a 91 z28 5 speed and I am going to install it into a 91 RS with a 700R4.
Will I have to change the computer and may be the loom to control the lock up on the torque converter?
Is there anything else I need to change other then the fuel pump to install this engine?
Thanks,
Alex
Thanks,
Alex
Transmission: 4L80E/4L80E
The TPI 5-speed harness won't have the harness leg that goes down to the transmission. It would probably be easiest to find a harness from an automatic car.
You won't have to change the computer, but you will have to change or flash the chip.
Sanjay
Aug 12, 2015 03:41 PM
